2000 Chevy Blazer cutting out at low rpms
10,000 MILES • 6 CYL • 4WD • AUTOMATIC
LPREZ
I have a 2000 Blazer that runs great when there is no moisture in the air or if it is not raining. But when its raining it wants to hesitate , but once it gets warmed up good or sits in the sun for awhile it will run fine. We have spent a ton of money and are tapped out trying to find the problem.
Could this be something electrical. Have replaced plug wires, plugs, fuel pump, pvc valve, rotor cap, and several other things . Please help I need my truck.
Sep 26, 2008 at 9:27 AM
MERLIN2021
  • 17,250 POSTS
It sounds like it could be the coolant temperature sensor or crankshaft sensor, have you tested or replaced it?
Sep 26, 2008 at 9:43 AM
LPREZ
Were do I find the crank sensor. Were is located and what does it look like. Also thank you I have never heard of a crank sensor.
Oct 3, 2008 at 4:40 AM
MERLIN2021
  • 17,250 POSTS
Under the ckank, held on by one screw.
https://images.2carpros.com/forum/automotive_pictures/62217_ckp_1.jpg
Oct 3, 2008 at 7:22 AM
