2000 Chevy Blazer Car Trouble
TRICIA21
  • 2000 CHEVROLET BLAZER
Electrical problem
2000 Chevy Blazer 6 cyl Two Wheel Drive Automatic
I live in Denver, early this week my husband drove my car to Tulsa. Now my check engine light is on and the code was 0440-evaporative emission control system malfunction. What does this mean, how do we fix it.
Wednesday, February 3rd, 2010 AT 6:59 PM
The possible causes of a code P0440 could mean one or more of the following :
1. The gas cap is not installed or working properly.
2. The purge solenoid has failed.
3. The canister is plugged and not working properly.
1. Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
2. Inspect the EVAP system for cuts/holes in tubes/hoses.
3. Inspect for damaged or disconnected hoses around the Evap purge solenoid.
4. Inspect and/or replace the sensor.
5. Inspect and/or replace the purge valve.
*I recommend you have a professional use a smoke machine to detect leaks.
Thursday, February 4th, 2010 AT 5:36 AM
