2000 Chevy Blazer Car stalling
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROSSYEARWOOD
My 2000 chevy blazer 4.3l v-6 will stall out occasionally. It cranks up fine in the morning, and I went to the gas station to grab a coffee and came back out and the car cranked right up. When I put it in reverse, the engine just cut off. It will turn right back on and rough idle for a few seconds and then be fine for my drive to work. The fuel pump is turning on and off as it should. I do not think it is a battery problem due to not having to reset the clock on my radio. I have not had a tune up yet, and would a fouled plug be the culprit or is to something to do with the fuel system.
Apr 1, 2010 at 10:55 PM
LEGITIMATE007
  • 5,121 POSTS
I think you may have a problem with the fuel system or the torque convertor clutch solenoid. check the fuel pressure when it starts to act up like that, and it wouldnt hurt to see how the ignition is either, but check ignition when you have that no start situation(obviously). and keep me posted.
Apr 3, 2010 at 6:36 AM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
