2000 Chevy Blazer break light
86,600 MILES • 6 CYL • 4WD • AUTOMATIC
DEERANDFISH6
I replaced break light on driver side. When I got home it stoped working. Why ???
Jan 5, 2010 at 3:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if bulb blew soon after replacing then either you fingered the bulb (oil from fingers on bulb will cause it blow quickly when used) or the housing is faulty and causing bulb to blow prematurely.
Jan 5, 2010 at 5:05 AM
