I replaced break light on driver side. When I got home it stoped working. Why ???
Jan 5, 2010 at 3:47 AM
BLUELIGHTNIN6
✓Experienced Mechanic
if bulb blew soon after replacing then either you fingered the bulb (oil from fingers on bulb will cause it blow quickly when used) or the housing is faulty and causing bulb to blow prematurely.
