2000 Chevy Blazer brakes going to the floor
REDOAK21
Hello.i recently changed my front brake pads,but noticed the brakes now go all the way to the floor,i have no leaks and bleed the entire system although i just changed the the front pads,wasnt doing it before i changed them,what did i do wrong,,thanks for your time...
Jan 29, 2008 at 9:07 PM
MERLIN2021
  • 17,250 POSTS
It's one of two things, first when you changed the pads did you open the bleeder BEFORE you retracted the piston? If not you may have blown a seal in the master, second, after you change front pads, you need to pump the pedal up until the pads actually contact the rotors...?
Mar 19, 2021 at 4:56 AM
MERLIN2021
  • 17,250 POSTS
If somehow you got air into the brake pressure modulator valve, you need the Tech II scan tool to bleed it out...
