2000 Chevy Blazer Both rear windows will not roll down.
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
SWROBEL
Neither of my rear automatic windows will roll down. They do not roll down using either the driver's or rear switches. Both stopped working at the same time. The fuse has been checked and is not the problem. I may have clipped a wire or something when installing new speakers or sub system, however I do not know where to start looking.
Apr 17, 2010 at 5:57 AM
RHALL77
  • 3,361 POSTS
check the areas you install the speakers and see if you see anything. also check and see i you have power to your switches
Apr 22, 2010 at 7:33 AM
