2000 Chevy Blazer ball joints
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
MENDO_SMOKE
after installing new ball joints (upper and lower) the knocking noise at take-off and stopping didnt get much better. any info or feedback on this subject would be great.
thank you!!!!!
Feb 26, 2009 at 6:10 AM
RHALL77
  • 3,361 POSTS
did you double check all your front end parts to make sure they were all tight.
Feb 26, 2009 at 6:48 AM
MENDO_SMOKE
everything is tight and i am almost 100% positive that the noise is the ball joints. how important is the type of grease. at first i used mag1 super lithium grease after new balljoint installation after driving for a few miles the noise came back so i then put in a redish collered chevron ultra duty ep nlgi2 grease
thank you for your timely reply and please state on your next reply wheather or not the grease IS or just MIGHT be the problem and if possable what grease i should use thank you!
Feb 26, 2009 at 8:17 AM
RHALL77
  • 3,361 POSTS
to be honest i never seen grease be a concern with that. I have used a ton of different styles and brands of grease and never had a problem
Feb 26, 2009 at 8:22 AM
MENDO_SMOKE
well i think the only balljoints that are loose arent the ones on my vehicle..... the ones in my head may need some new grease though.... at the same time i greased up the balljoints and ruptured the seals i also oiled the door hinges. well with doors open the noise mysteriosely dissapeared thanx for your time and if i have any more lamebrain questions i will give you another dollar to tell me i'm an idiot!!!!!!!!
thanks again
dustin west
Feb 26, 2009 at 9:40 AM
