4 wheel drive buttons the light blinks for a while and then switches back into 2WD
BLAZER2000
MEMBER
2000 CHEVROLET BLAZER
6 CYL
4WD
AUTOMATIC
93,000 MILES
When I push any of the 3 4 wheel drive buttons the light blinks for a while and then switches back into 2WD.
Saturday, March 1st, 2008 AT 10:26 AM
MASTERTECHTIM
MECHANIC
With ignition key on push 4wd button and listen under center of truck for a clicking noise. Try disconnecting battery and reconnecting it. This will clear tcm memory. Get back to us at this post.
SPONSORED LINKS
Friday, May 14th, 2021 AT 12:29 PM
MASTERTECHTIM
MECHANIC
The noise you hear under truck tells me your 4wd encoder motor is working but front diff is not actuating. First thing you need to do is when you put it in 4wd slowly move forward and have someone watch front driveshaft to see if it is moving. If it is then we need to look at the front diff, if its not we need to look at transfer case. Get baCK TO US
