2000 Chevy Blazer 4 wheel drive
12,000 MILES • V8 • 4WD • AUTOMATIC
TRUCK12
my car will not disengage from 4 wheel drive. help
Nov 26, 2009 at 11:56 AM
  • 110,246 POSTS
Are you getting power to the 4wd actuator mounted to the transfer case? It is the electric engine that engages and disengages the 4wd.
LEt me know.
Nov 28, 2009 at 12:23 PM
TUNEUP1200
  • 18 POSTS
If you're 4WD is push-button type:
You will need: small screwdriver, q-tips, and rubbing alcohol.
Pop out the 4WD button assembly from the dash. Unplug the the two wire connectors. Hold the button assembly in your hand face down. make sure you are in a place that, if you were to drop something small you can find it easily, but lets just hope you're careful. With a small screwdriver, pry the back of the assembly from the front....remember to keep the face down in your hands at all times. You see those blue boots with metal contacts on them? These are the things that will fall out easily. Take your time, remember where these boots are located they will pop out easily. In fact , have someone handy with a camera to take a picture of it before going further. Now with a q-tip dipped in alcohol gently clean the metal contacts in the blue boots. Then, with the q-tip and alcohol, clean the whole face of the board that the blue boots come in contact with, paying close attention to the white circle patterns on the board. They may not look dirty but it doesnt take much to make this assembly act nutty. When done cleaning and parts a fully dry, re-assemble and give it a try. Let me know if it works!!
Dec 10, 2009 at 3:43 AM
