2000 Chevy Blazer 4 wheel drive
2000 CHEVROLET BLAZER
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
DEMARI4
my truck is stuck in 4 wheel drive on the driver side front tire,the mechanic told me i need a new diferencial because it is locked up. but i was told that it could be the vaccume line. we bought a new switch and all the lights on it still light up, but not all the time, most of the time. what should i do?
Mar 9, 2009 at 4:05 AM
JAMES W.
  • 2,394 POSTS
I would pull the vacuum actuator and verify it is functioning. If it is, you can manually move the lug that the acuator moves and see if disengages the front axle. If you can't move the link while moving a wheel back and forth, you probably have internal damage. Hope this helps.
Mar 9, 2009 at 5:52 AM
