My car doesn't start in the cold is there anything I can get to keep my fuel pressure high and flowing when the temp drops?
Monday, May 11th, 2009 AT 12:14 PM
RHALL77
MECHANIC
Do you have a check engine light on? You may have a problem with your temp sensors causing a no start condition. Also you need to check your fuel pressure and see if that is up to spec
SPONSORED LINKS
Monday, April 9th, 2018 AT 2:27 PM
REDSKINSCHAMPS23
MEMBER
No the check engine light isn't on, but I noticed that when my battery is warm it starts. I also use 5w30 oil. Should I use a thinner oil.
RHALL77
MECHANIC
Have you had your battery load tested to see if it can take a draw when starting
REDSKINSCHAMPS23
MEMBER
Would regular gas keep it from starting? When I put premium in it isn't as bad
RHALL77
MECHANIC
As long as the gas isn't to old you should be ok with any type of gas
SPONSORED LINKS
REDSKINSCHAMPS23
MEMBER
Also I have 4 wheel drive but the car is stuck in 4hi. It's supposed to be at 2hi would that be related to it not starting?
RHALL77
MECHANIC
That shouldnt have anything to do with it
REDSKINSCHAMPS23
MEMBER
I figured out that it was the battery losing charge overnight. What could be causing this? The battery is brand new I bought it 3 months ago
