2000 Chevy Blazer 6 cyl Four Wheel Drive Automatic 92k miles
M_J_KINTZEL I have talked to you about my heater always blowing hot air. It is not because the a/c doesn't get cold because the unit gets extremly cold under the hood. The air inside the vehical is always hot. It is like the heater is always on no matter were the temp knob is set. It also gives out hot air even if temp is set to cold and the control knob is set in the off position. Thank you!
SPONSORED LINKS
Tuesday, March 17th, 2009 AT 9:00 PM
