The main problem with not heating is low coolant level. So, instead of filling up to the ADD line, why don't you fill it up to the MAX line. You may not have enough to begin with. That is probably why you have to fill up twice in a week.
Once you fill up to MAX line, let the engine run to normal temperature, and shut the engine off. Open your hood and listen for any "hissing" sound. You may have a leak that just hasn't surface. Also check the reservoir container to check if it is boiling.
Let us know.
SPONSORED LINKS
Saturday, January 10th, 2009 AT 2:05 AM
