1999 Chevy Blazer vibrations thru brake pedal
195,000 MILES • 6 CYL • 4WD • AUTOMATIC
BECKYENGLISH
On my 99 blazer there is a vibration that comes thru the brake pedal when I make a left hand turn and step on the brake. Now it is starting to do the vibration when I make a left turn. The pedal recently started going to the floor when this happens. I have had three people take the tires off and check everything. They found nothing wrong. What can be doing this?
Aug 26, 2010 at 5:07 PM
  • 75,988 POSTS
The vibration could be caused by a warped brake rotor/s for the pedal sinking to the floor could be an internal leak in the master cylinder or you're leaking somewhere else
Aug 26, 2010 at 9:24 PM
