1999 Chevy Blazer turn signal
1999 CHEVROLET BLAZER
137,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARK9919
My 1999 s-10 blazers turn signals just all of a sudden stopped working , there is nothing when you raise the lever up or down to signal , fuse is good and has current when switched on , i was told to check the turn signal flasher i can only find one flasher that is behind the glove box that reads combination flasher it has four prongs could this be my problem ? the multipupose switch on the steering wheel all other functions work fine
Jan 25, 2010 at 9:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yes flasher is most likely the culprit. do the hazards work? the flasher controls both the signals and the hazard so if the hazards still work then the switch is faulty. if hazards don't work either then replace flasher relay.
Jan 25, 2010 at 12:59 PM
NAMIRTHA
The flasher may be faulty due to some electric connections loose connection or it may spoiled totally.
Jan 25, 2010 at 1:11 PM
