1999 Chevy Blazer transmission doesn't shift
1999 CHEVROLET BLAZER
182,000 MILES • 6 CYL • 4WD • AUTOMATIC
DOCKTER9317
it seems the 2nd gear position is 1st and the 3rd is 2nd and D is 3rd and wont shift into overdrive I'd also like to know if the transmission plugs into the same computer along with the engine.
Oct 5, 2010 at 4:55 PM
HMAC300
  • 48,601 POSTS
probably the trans is starting to go bad. have a trans pro hook a computer up to it and he can find out what's wrong. Yes the same computer runs the trans and engine that's why it's called a PCM- powertrain control module......
Oct 8, 2010 at 12:29 PM
