Hello, just some possibilities, water pump-- thermostat--clogged radiator-- cooling fan-- coolant temp sensor, maybe an air pocket in the cooling system, maybe an engine issue? I'm not saying replace anything, I'm just listing possbilities
I'd remove the thermostat, hook everything back up, start the vehicle, check for coolant flow through the radiator. That should show that the water pump is working.
SPONSORED LINKS
Wednesday, August 19th, 2009 AT 10:09 AM
