1999 Chevy Blazer Sucky Truck
10,060 MILES • 6 CYL • 4WD • AUTOMATIC
HARTSDC
My truck wobbles when I slow down or start out. When I hit about 30 or 35 it evens out, but then I hear this loud humming sound. The only time it goes away is when I turn this sharp curve that goes to the right. It then stops completely. I do have a cracked rim and a totally balled tire on the back drivers side. I had my ball joints replaced two years ago. that is the only service I have done. The truck also seems to slam every bump in the road. It isn't a smooth ride at all any longer. Even small, repaired pot holes make everything rattle. The wobbling is driving me crazy! I lost half of my pay so money is waaaaay too tight right now. Am I safe putting off the repair and what could it be? Thank you.
Aug 6, 2008 at 2:05 AM
LUKEVAN
  • 10 POSTS
your problem does infact have to do with your rim/tire but it could also be your driveshaft. Does it "Tunk" when you put it in gear from park?
Sep 10, 2008 at 1:46 AM
