1999 Chevy Blazer starting
WHEATRIDGE
Engine Mechanical problem
1999 Chevy Blazer 6 cyl Two Wheel Drive Automatic
starts fine when eng is cold. After driving and turning off and sets for 15 minutes, it will start for about a second then die, cranks for about 10 seconds then starts and runs fine. has been tuned up and a new fuel pump has been installed. Has no codes. Fuel pressure is fine and does not bleed off.
Jan 22, 2009 at 1:09 PM
  • 75,988 POSTS
Test the fuel pump relay and the oil pressure sending unit then get back
Jan 22, 2009 at 8:15 PM
WHEATRIDGE
[quote:589442cf99="rasmataz"]Test the fuel pump relay and the oil pressure sending unit then get back[/quote:589442cf99]
Jan 26, 2009 at 12:06 PM
