1999 Chevy Blazer sputter on acceleration
150,977 MILES • 6 CYL • 4WD • AUTOMATIC
REDDRUMS
when accelerating(engine cold)engine losses power
until you let off the gas.It also sounds like its backfiring thru the catalitic converter(almost a popping sound
Nov 5, 2010 at 10:40 AM
  • 75,988 POSTS
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Nov 5, 2010 at 10:46 PM
