1999 Chevy Blazer spits and sputters
CGC
  • 1999 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 160,000 MILES
I have a 99' chevy blazer v6 4wd and if I don't let it sit and run for a few min after I start it it cuts out and drives really slow for about a min then it's fine. My uncle is a mechanic and he told me he thought it was a fuel filter so I changed it and it hasn't helped. Could you give me your oppinion on what wrong with it? Thanks
Wednesday, August 11th, 2010 AT 9:10 AM
Lack of acceleration, chugging, hesitating, bogging, misfiring etc. Could be caused by one of the following below:
Start here inspect and test all the items below and comeback with results.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Saturday, August 14th, 2010 AT 4:58 AM
