1999 Chevy Blazer Replaced rear brake line, no fluid to rea
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
SANTS231
1999 Blazer LT, 4wd, rear disc brakes, Kelsey Hayes ABS.
The rear brake line rusted out and emptied the front resivoir on the master cylinder. I refilled the master cylinder and it did not leak any more.
Since, I have replaced all the steel line to the rear, all 3 rear hoses, rear calipers, pads, rotors, and installed a new master cylinder.
I can not get any fluid through the ABS unit to the rear. Not even with a professional pressure bleeder. Is there something in the ABS module that would have shut pressure off the the rear because of the fluid loss?
If so, is there a way to reset it with out taking it to a dealer?
Nov 25, 2009 at 1:31 AM
MERLIN2021
  • 17,250 POSTS
Gm Tech II scan tool needed to bleed abs...
Nov 25, 2009 at 3:00 AM
