1999 Chevy Blazer PO300 - PO399 Numbered Code Identificatio
JPABLO84
Engine Performance problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Causes for a P0300 code?
Mar 10, 2010 at 5:05 AM
LEGITIMATE007
  • 5,121 POSTS
if I am not mistaken, that is multiple misfire, which can be alot of things, starting with the ignition module, egr valve ,intake maniflold gasket leak, multiple spark plugs or wires at fault. could be several bad injectors. so there are many things to check, even a bad catalytic converter.
Mar 10, 2010 at 6:18 AM
