1999 Chevy Blazer P1351
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
OLDROOKIE
  • 6 POSTS
Hard start mostly when cold. Dealer said it was ignition module. Wrong. Have factory service manual. Have gone thru list of checks as far as I could. Is there a common failure associated with this code?
Oct 12, 2010 at 1:28 AM
WRENCHTECH
  • 20,760 POSTS
I am curious as to why you think the dealer is wrong and you are right?
Oct 12, 2010 at 1:33 AM
OLDROOKIE
  • 6 POSTS
1. Because I replaced the module and this morning the starting symptoms were exactly the same. 2. The service manager told me, " The technician feels the problem is the ignition module". I translate THAT statement to: " You said you only wanted a diagnosis, so we aren't going to check anything just for a diagnosis charge. All you get for that is a guess." I will have the new module checked this evening just in case it is bad. It is an aftermarket module. It is a brand name not the store brand. I have never had a failure of this brand in my life. But the posibility is there. I've been wrenching for 45 years so my experience with this brand is extensive.
Oct 12, 2010 at 2:24 AM
WRENCHTECH
  • 20,760 POSTS
Have you checked all your grounds and associated wiring? The issue is "voltage high" which usually means an issue on the ground side of the circuit.
Oct 12, 2010 at 2:32 AM
OLDROOKIE
  • 6 POSTS
My exploration this far has been ohming and jumping the power side. I have ignored the negative side. I have the earliest service manuals available for these models. Bought vehicle new. I always order service manual first thing. Will follow your suggestion and check grounding. Thanks.
Oct 12, 2010 at 2:43 AM
OLDROOKIE
  • 6 POSTS
Thanks for schematic. After covering the same ground again; ohming, jumping etc. I still found nothing. I decided to cover the fuel side AGAIN. Put two ounces of gas in TB and it fired right up. Hooked up pressure gage again this time it was below minimum. Even at that pressure was bleeding off 10 psi in 20 minutes. That pointed to check valve or pressure regulator. Went to bed. Thought about it in depth. If it is the regulator; the gas has to be going somewhere. Next morning I checked oil level. Sure enough it was almost a quart high! Changed out spider assembly. Installed new premium rotor and cap. Oil change. Cycled key three times; Started on first crank! I think repeated cranking with marginal ignition components will cause the VCM to throw a intermittent P1351.
Oct 17, 2010 at 11:39 AM
WRENCHTECH
  • 20,760 POSTS
I wouldn't bank on that theory. You could have disconnected something during testing that set the code. Lets see if it sets again after clearing.
Oct 17, 2010 at 11:43 AM
OLDROOKIE
  • 6 POSTS
Time will tell.
Oct 17, 2010 at 11:46 AM
