1999 Chevy Blazer No Fuel being injected
123,000 MILES • 6 CYL • 4WD • AUTOMATIC
POOKIE42
I have a vehicle that was in the storm and sat for 6 months. I then replaced the spark plugs and the crank sensor,I replaced a burned fuse in the fuse relay box under the hood and then I poured gas into the throttle body to try and start it. I cranked it up and it ran only long enough to burn the fuel I put into the throttle body and then it stalled. I tried to pat the gas peddle while its running and the engine did not rev up. Can you help?
Mar 11, 2010 at 12:42 PM
  • 75,988 POSTS
Do you hear the fuel pump coming On for 2 secs when key at run if so check fuel pressure if its within specs if okay if not check the fuel pump fuse and fuel pump relay-could be very well be no power to the injectors or the computer ground drivers for the injector/s is defective
Mar 11, 2010 at 1:20 PM
