1999 Chevy Blazer No Brakes!! ahhhh.
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
CASTINGSHADOWS2
1999 blazer 4wd abs. no brakes. brakes grab slighly at first then let go and the pedal goes to the floor. no leaking fluid, but have had a problem with the abs trigering itself for no resaon.
Sep 9, 2010 at 10:10 AM
MMPRINCE4000
  • 8,548 POSTS
ABS should set a code, a "C" chassis code.
More that likely it is the MC, since you have no leaks.
Sep 10, 2010 at 1:22 AM
