1999 Chevy Blazer LS
REDBANK1980
  • 1999 CHEVROLET BLAZER
I bought a used Blazer drove it for over 1hr on intersate and through town brakes worked fine. After a summer rain storm the brakes locked up when I touched them. The ABS light is on. I barely touched the brakes and the car continued to move and the brakes sounded like they were grinding. What do you think?
Friday, June 8th, 2007 AT 8:26 PM
E40WATER12
  • 522 POSTS
If you are able to change or place the brakes pops off front and back tires, and inspect the front brake pads and rotors, Then with te rear brake drums, They can be a real pita to remove to inspect, block the front wheels with brick or piece or wood, Then get a hammer piece of wood place the wood on the side of the rear brake drum then, stirke is hard, with the hammer hiting the wood, Then trying wiggling the drum off the car. Then inspect the brake drum for grooves and markings, Also see what kind of condition the rear brake shoes are in.
Saturday, June 9th, 2007 AT 6:38 PM
