1999 Chevy Blazer left front not working
1999 CHEVROLET BLAZER
89,600 MILES • 6 CYL • 2WD • AUTOMATIC
LEONARD MOORE
I had leaking brake lines on the front and the center one rear ,after replacing the lines i bleed the brakes and the front left caliper does not work and will not bleed properly . The fluid coming out at the bleeder is coming out at a slow drip.it has new calipers ,rotars pads,master cylinder,and lines.the lines have all been flushedthe ABS to the wheel so there are no clogs in the lines.I have three good brakes out of four
Feb 10, 2009 at 7:19 AM
  • 110,194 POSTS
When you bled the brakes, did you start with the furthest from the master cylender (R. Rear) and work your way to the left front?
Mar 19, 2021 at 11:57 AM
LEONARD MOORE
in answer to your question,is yes I started at the right rear brake{pass. side} and worked my way around.autozone strikes again,it took two more times changing the left front caliper ,but I finally got a good one for that side.the brakes are now functioning ass they should .thanks for the help.
  • 110,194 POSTS
Glad it's finally working. I know bad parts are out there, but when you are the one that gets them, it can really be a pain in the butt.
