1999 Chevy Blazer In drive but display reads reverse
1999 CHEVROLET BLAZER
SIMZ
Transmission problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I am just wondering what can be done to fix this problem. Can I do this on my own or does the vehicle have to be brought into a shop.
Oct 19, 2010 at 2:07 PM
HMAC300
  • 48,601 POSTS
if you have a cable style shifter you'll probably need a new cable, they may be in two pieces. then after you install the new cable make sure theere is a ground wire from the engine to the firewall. It may be out of adjust ment as well. try that first.
Oct 21, 2010 at 12:31 PM
