1999 Chevy Blazer horn problem
13,300 MILES • 6 CYL • 4WD • AUTOMATIC
BBUSH24
I changed out the horn fuse and relay and bought a new horn. It will sound with the alarm but not when I press the wheel.
Feb 3, 2010 at 4:14 PM
  • 110,248 POSTS
Is the air bag light on?
Feb 4, 2010 at 2:37 AM
BBUSH24
no the air bag light is not on
Feb 4, 2010 at 9:45 AM
  • 110,248 POSTS
Chances are the problem is in the steering wheel. One problem, the airbag needs to be worked around. I would recommend taking it to a shop that is familiar with working with them. Unless you feel comfortable.
Feb 5, 2010 at 10:47 AM
BBUSH24
I was told something similar, would you have any idea of how much that would cost and where I could go to get it fixed?
Feb 5, 2010 at 12:55 PM
  • 110,248 POSTS
I'm not sure where you live or anyone near you. A dealer could fix it. As far as cost, chances are they should be able to remove the steering and check and repair it within 2 hours.
I wish I had better news for you. Regardless, thank you for using 2carpros.com.
Feb 6, 2010 at 3:52 PM
