1999 Chevy Blazer Grinding noise
165,250 MILES • 6 CYL • 4WD • AUTOMATIC
WAYNESAR
When I turn right, either slow or down the road. There is a loud grinding noise that seems to be coming from the drivers front end. I've pulled the front wheel off, but can't seem to find anything. The CV boot was replaced a few months back because it was ripped. I'm thinking it might be a bad CV joint, short of pulling it apart what can I do to check it? Or could this be the wrong thing I'm going for?
Apr 30, 2008 at 11:51 AM
LEGITIMATE007
  • 5,121 POSTS
YOU MAY BE ON THE RIGHT TRACK, THE CV JOINT COULD'VE ALREADY BEEN CONTAMINATED WHEN THE NEW BOOT WAS REPLACED, BUT IT CAN ALSO BE A HUB BEARING PROBLEM. WHICH i'M LEANING MORE TOWARDS. BECAUSE CV'S WOULD MAKE A CLICKING NOISE WHEN TURNING. TO CHECK YOU WILL HAVE TO PULL THE BOOT BACK OFF AND LOOK FOR GOUGES AND DIVITS IN THE JOINT
Apr 30, 2008 at 2:04 PM
