have 99 chevy blazer when driving at 65 to 70 mph a loud grinding noise when slow down and shift to 4 wheel high it goes away HELP
Feb 6, 2010 at 11:15 PM
FACTORYJACK
✓Experienced Mechanic
If it goes away when the mode in the transfer case is changed, that could be an indication of where the problem is. I would drain and inspect the fluids from the transfer case, as well as the front differential.
Feb 7, 2010 at 4:15 AM
SCOTT1967
MEMBER
thanks will do that will post outcome
Feb 8, 2010 at 9:04 AM
