1999 Chevy Blazer FUEL VAPOR PRESSURE REGULATOR
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALUAP62
OUR 1999 CHEVY BLAZER IS BLOWING FUEL OUT THE EXHAUST. tHE PERSON AT THE AUTO PARTS STOR SUGGESTED WE TRY A FUEL VAPOR PRESSURE REGULATOR. wE PURCHASED THE PART BUT DO NOT KNOW WHERE IT IS LOCATED. iS THERE A DIAGRAHM OF OUR MOTORS FUEL SYTEM TO HELP US LOCATE THIS PART
Dec 29, 2009 at 1:52 AM
OBXAUTOMEDIC
  • 3,711 POSTS
It will depend on the type of injection system....
If it is a CSI System - meaning it has a converted Carburator. It is located under the Upper Intake Manifold.
If it is a SFI System - meaning there is an Injector for each cylinder. It is located at the end of the Fuel Rail.
However, I am not sure that is you problem.
Is the engine light on? If so need to get codes pulled and post them here.
It could be any number of things causing you problem...
Leaking injector/s
Bad O2 Sensor
Bad Coolant Sensor
Vacuum Leak
Leaky EGR Valve
Plus others.
Dec 29, 2009 at 3:01 AM
