1999 Chevy Blazer fuel system
BLKKNIGHT
  • 1999 CHEVROLET BLAZER
Engine Performance problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I have a 1999 blazer, and I just replaced the FPR, and I still am having problems with cold starts. To the my truck in the morning, ill have to spray starting fluid for it to start, but once the truck has warmed up and has been driven for a while, it will start up with no problem, can anyone give me a glue to the next time I need to take. Thanks.
Sunday, April 19th, 2009 AT 4:41 PM
  • 109,772 POSTS
Hi:
Have you had the temp sensor tested? Also, have you checked fuel pump pressure when cold?
Monday, April 20th, 2009 AT 5:16 PM
BLKKNIGHT
  • 9 POSTS
Yes I did check the fuel pressure while cold, it hoers around 60psi before starting.
Monday, April 20th, 2009 AT 6:18 PM
BLKKNIGHT
  • 9 POSTS
And one more thing I need to add to my last reply, when your driving after the truck starts, it make a whistle sound from the rear area.
Monday, April 20th, 2009 AT 8:45 PM
  • 109,772 POSTS
Check to make sure the fuel tank vent is good and not bad.
Tuesday, April 21st, 2009 AT 8:01 PM
