1999 Chevy Blazer fuel injection
TAZMAN5150
Engine Mechanical problem
1999 Chevy Blazer 6 cyl Two Wheel Drive Automatic
Is there a sensor that would cause the fuel injectors not to work. And where would it be
Jul 3, 2010 at 9:13 AM
  • 75,988 POSTS
Check for power to the injector/s if okay use a noid lite on the injector harness it suppose to flash when cranking engine over if not there's a problem in the computer ground drivers circuits
Jul 3, 2010 at 10:33 AM
