1999 Chevy Blazer Front Shock Replacement
SAT26NAU
Suspension problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I can't remove my front shocks now that I have them unbolted. How am I supposed to get them out or put the new ones in? I've unbolted the top and bottom and that's as far as I can get.
Thanks for you help!
May 28, 2008 at 3:33 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Did you jack up the vehicle to take tension off shocks? If not you will need to jack vehicle at a place were it will let the front wheel remain on ground. and jack until you can remove the shock.
May 29, 2008 at 10:45 AM
