trying to remove my right cylinder head?
1999 CHEVROLET BLAZER
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBSAC
im trying to remove my right cylinder head and i have the ground wire from the back of the head off but dont know what else could be holding it on it looks like the fuel lines but im unsure do you have a solution
Dec 15, 2007 at 11:11 AM
BLACKOP555
  • 10,386 POSTS
does it still feel like it is bolted to the block or can you move it a few inches till it slowly stops.
Dec 15, 2007 at 2:01 PM
  • 55,423 POSTS
Yep, there is a bracket on the rear of the cylinder head you must undo. Also, double check that all head bolts have been removed.
Oct 29, 2024 at 9:55 AM
