1999 Chevy Blazer changing headlight bulbs
1999CHEVYBLAZER
Electrical problem
1999 Chevy Blazer 6 cyl Two Wheel Drive Automatic 100k miles
how do you change bulbs on headlights in a 1999 chevy Blazer. I need to replace the passenger side lights, but I also want to replace the drivers side also.
How I get to it. Do I have to remove the battery, how do I remove the headlight so I can have access to the back of it to replace the low and high beam bulbs.
Mar 20, 2010 at 6:08 PM
1999CHEVYBLAZER
Electrical problem
I figured out how to replace the headlight bulbs in my 1999 chevy blazer, Open the hood, on the inside of the support on the left and right of the radiator, there are two plastic pieces that are about 4 or 5 inches long, if you lubricate the plastic peices you can pull them up and the headlight comes right out. Simply replace the bulb, put the headlight back into the car and slide the two plastic pieces on and you are done. (there is a little lip on the plastic pieces that you can pull on, take it easy they are plastic, too much force or prying them could break them)
This is the same for both sides (driver and passenger). It is super easy when you know how.
Mar 21, 2010 at 12:02 PM
