1999 Chevy Blazer car problems
200,000 MILES • 6 CYL • AWD • AUTOMATIC
CRYSTAL40
car will not fire but battery /alternator are fine, also power locks and hatch switch do not work
Nov 27, 2008 at 2:46 AM
F4I_GUY
  • 3,302 POSTS
So the vehicle does not crank?
Have you tried boosting it? Are your connections good and tight?
Have you checked for power at the starter motor? Both the 12V live feed and the solenoid power while you are cranking the vehicle?
Could be numerous things. For the time being, I would ignition the door lock situation, this is most likely un-related.
Nov 27, 2008 at 10:52 AM
