1999 Chevy Blazer break lines
99,000 MILES • 6 CYL • 4WD • AUTOMATIC
EBETEC
how expensive is it to change a break line
Nov 30, 2008 at 1:22 PM
  • 110,248 POSTS
Hi:
The steel brake line is cheap. It's the labor that will be expensive. I don't know what lines need replaced, how many needs replaced, or the labor rate in your area. However, if there is someone you trust, it shouldn't be too bad.
Dec 1, 2008 at 12:58 PM
