1999 Chevy Blazer BRAKES
182,000 MILES • 6 CYL • 2WD • AUTOMATIC
KBCOULBOURNE
My brakes paddle goes to the floor why you are stopped at a light and when you crank the car up? What is the problem. Replace back pads, master cylinder, new brake fluid found 2 vaccum leaks.
Mar 23, 2008 at 10:14 AM
  • 75,988 POSTS
No leakage within the brake system.
Recheck the brake master cylinder by bleeding it and the rest of the wheels and see what happens-if it continues it still points to the brake master cyl. Does it have an ABS
Mar 23, 2008 at 10:55 AM
