There are no p codes that come up, only flashing letters, (C, O, EV, OH, E) I can start the vehicle fine and it will run while it is in park with no problems, but when I put it in drive after it has been running for a while then it will start to sputter, and I have no power it almost wants to stall but it does not. I can`t even get above 20 mph. But if I start the vehicle and drive it immediately it is ok for about 2 or 3 minutes and then it losses its power and begins to sputter and then I can`t get above 20 mph. I have tried unplugging different sensors and running the codes and then I do get a P number but that goes away once I plug the sensor back in. After clearing them I go back to just getting the letters flashing. Thank you so much for taking the time to help me with this.
SPONSORED LINKS
Saturday, March 22nd, 2008 AT 9:06 AM
