Electrical problem
1999 Chevy Blazer Four Wheel Drive Automatic
I have a chevy blazer. After you shut off the engine everything is off. About a minute later the blue high beam indicator light comes on. If I don't use the car and it's left to sit, it will drain the battery in 3 days. I pull the DRL relay and the light stays on until I pull fuse #19. It operates the gas and temp gauge, speedometer, clock and shift indicator. What is wrong and how can I fix it?
Nov 5, 2008 at 9:32 AM
