1999 Chevy Blazer
1999 CHEVROLET BLAZER
SUPERDAVE09
Electrical problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
i changed the motor out in my 99 blazer with a02 motor.both were 4.3.i swapped over all sensors.truck runs fine but i lost fuel guage,coolant temp.,gear indi icator.also batt. light on.i checked all fuses.with the key on there is no voltage on radid,batt. cluster, cruise,or guages circuits
Dec 23, 2009 at 7:38 AM
JDL
  • 16,098 POSTS
welcome, thanks for the donation. Gage fuse 4, 10 amp, is that fuse circuit hot, when you turn on the key? If not, I' have to check circuits to and from the ignition switch. The feed to the switch, for that fuse circuit, is a solid red wire, hot all the time. The feed from the ignition switch to the fuse circuit is a pink wire, goes hot when you turn on the key. I'm not sure what we're going to run into?
Dec 24, 2009 at 5:33 AM
