1999 Chevy Blazer
BRANDON M
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
how to take the starter out it a tite fit
May 29, 2010 at 5:49 AM
  • 75,988 POSTS
Notes REMOVAL PROCEDURE CAUTION: Refer to Battery Disconnect Caution in Cautions and Notices.
https://images.2carpros.com/forum/automotive_pictures/12900_s1_2.gif
Disconnect the battery negative cable. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle Remove the front tire and wheel assembly from the right side of the vehicle. Remove the differential carrier shield mounting bolts, if equipped. Remove the differential carrier shield, if equipped.
https://images.2carpros.com/forum/automotive_pictures/12900_s2_2.gif
Remove the wires from the solenoid.
https://images.2carpros.com/forum/automotive_pictures/12900_s3_1.gif
Remove the starter mounting bolts by accessing them below the right wheel house panel.
https://images.2carpros.com/forum/automotive_pictures/12900_s4_1.gif
Remove the starter from the vehicle. Note the location of the shims, if equipped. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
May 29, 2010 at 6:00 AM
