1999 Chevy Blazer
124,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEEPGIRL1024
blazer will not start but will turn over the battery is fine
Jan 26, 2009 at 5:28 AM
JDL
  • 16,098 POSTS
Can you check fuel pressure? Do you have that spider fuel system?
If you can't check codes, you might do some basic tests. Have a helper crank it while you check for spark at the plugs, If you have spark everywhere, check the fuel system.
Jan 26, 2009 at 5:38 AM
