Which headlight system? Sealed beam or composite, And how are the lights arranged if it is the composite lamps? There are 3 different possible systems.
The sealed beams use different adjusters on the bulb sockets. The composites use an internal torx bit on a long rod that drives a gear box. If they haven't been adjusted in a while the gears are probably rusty and the adjusters will break. Then you get to replace them.
Dec 17, 2009 at 4:46 PM
