1999 Chevy Blazer
BRANDONSNOW
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
HI I have a 1999 chevy blazer LS with auto 4wd, 2 HI, 4 HI, and 4 Low but the transfer case is gone so I'm wondering if you could make a manual transfer case out of a older model fit..
Dec 16, 2009 at 2:34 AM
SWILLIAMS
  • 597 POSTS
Well you could BUT it will require a few other pieces.
First you would need to get a manual box, then modify the floor pan and console to work with the lever. Then you will need to change out the front differential to one of the non auto4X4 units.
You will need to come up with the wiring to the ABS and ECM to tell them when you're in 4X4 (the ABS has different programming as does the ECM when in 4X4 mode)
Then there are various other minor items you would need to alter to keep the computer happy.
Dec 17, 2009 at 3:37 PM
