1999 Chevy Blazer
BEZER15
Noises problem
1999 Chevy Blazer V8 Four Wheel Drive Automatic
When the Blazer is running there is a tickinh noise like a turn signale is on, when I hit the brake the noise goes away. all fuses are still good. any advise?
Nov 26, 2009 at 6:07 AM
JDL
  • 16,098 POSTS
Welcome to the forum, are there any external turn signals working, when you hear it, indicator on the dash? Your lower brake lites and turn use the same bulb filament, just not at the same time. Possible problem with multifunction switch or wiring circuit?
Nov 26, 2009 at 6:30 AM
